I know Convergent advertises 240fps when pairing the 7Q and the FS7.
How does this work since the max frame rate on the FS7 is 180fps? On the FS700, the frame rate is set internally to 240fps, but since the FS7 does not go that high, where would you set the 240fps frame rate on the 7Q?
