I was runnig firmeware 4.02, everthing worked fine.
I installed firmeware 4.03 an RAW upgrade.
Since that moment the ENTER butten/wheel does not work properly. When i press the enter-wheel 50% it works and 50% no reaction so that i have to power the camera off. I restart and same problem again.
Factory reset and loading saved camera stettins from SD card did not solve.
This means 50% the navigation through menue settings dont work, i see all menue points but cannot select them.
I want to find out if is a firmware 4.03 problem or a mechanical problem of the wheel-button (the inside electronical od physical connections)....before sending the cam to sony support.
Is there a way to go bck to firmware 4.02 to check this probem ? Which workflow has to be used to go down 4.02 ?
I please for help
Thanks, klfi
I please for help
Thanks, klfi
