Hi,
For the second time just experienced my FS100 not turning off. When it happened for the first time I thought it was due to using S&Q mode with 1 frame per second. I tried this mode for the first time, camera did the recording but when I tried to stop it and pressed the REC button it did not stop and continued recording. Turn off switch didn't help either, camera just continued recording. Only removing battery would stop it and turn it off. After switching camera back on I got a warning saying that camera has to recover the recorded data which might get lost. Eventually, after doing something, camera fixed the 'lost' recordings and worked fine.
And now, after few days of flawless functioning, I got the same thing again. Only this time it was not connected due to use of S&Q mode but happened during normal shooting. Same thing - repeated REC button push would not stop it, nor the camera turn off switch. Only removing battery.
Has anyone an idea what's happening with my camera? And what has to be done to fix it.
