If you have a choice of lenses then the Nikon mount will be less expensive (assuming you want to control iris) as its all mechanical. If you already have glass, then choose the mount that will work with your lenses.
quite rightThe advantage of the Canon mount is that with a smart adapter like metabones, you will be able to use Image Stabilisation if you lenses support it. With nikon mount, it,s impossible since there is no smart adapter on the market yet.
Birger adapter isn't out yet.
Advantage of Nikon lenses is that you can adapt them to Canon bodies and also use them on Nikon bodies. That's a small disadvantage to Canon-mount lenses; you can use them on Canon-mount bodies but cannot use them on Nikon bodies. So if you want the lenses that have the most adaptability, Nikon is a better bet. If you're only ever going to use the lenses on Canon bodies, by all means get Canon-mount.
