gkantziper
Esteemed Member
My question involves shooting with the HVX200 mated to the FS100 set to P2n mode. Is the following true?
If the HVX is set to 720/30 at a frame rate of 60FPS and the FS100 is set to P2n, is that going to yield the same recording as the HVX set to 720/30 at 60FPS with the FS100 set to P2?
In other words, does it matter whether you are in P2n or P2 in the 2x slo mo in the above combination of settings and is the same thing is recorded to the FS100 (no savings of space either in native in that case)?
To put it yet another way, does P2n setting on the FS100 record whatever frame rate the HVX is set to?
