fs100 has no 24p 0r 60p!!?? help!
aras
I just bought a second hand fs100 and in the menu i cant find 24p or 60p anywhere
all i have is 25p and 50 p and a bunch of others ( also no 30p)
I see now that it is a pal ntsc thing..and just in case anybody looks this up, the newer firmware does enable all frame rates for both pal and ntsc
This update will work both ways? ie: enable 60Hz recording on a 50Hz FS100 and enable 50Hz recording on a 60Hz FS100 ?
Hi Rob, The setting is under the ¨Others¨menu, as 60i/50i SEL - note you need a formatted card to change - its not possible to record both formats (25p and 24p) on the same card. With the firmware update all cameras can do both - it became a world camera.
paul-
thank you for the quick response.
got it.
goofy that sony didn't put the options where the other "flavors" resided.
ymmv
be well.
rob
smalltalk productions/nyc
