FS100 and LA7200 1.33x anamorphic adapter
mandrean
Has anyone shot with the FS100 and the Panasonic AG-LA7200 1.33x anamorphic adapter?
Impressions?
How wide can you go on the S35 with it's 1.5x crop factor?
I have both.. I will post some tests soon.. So far just looking at it through the LCD monitor. It looks great.. Once I post a test I will let you know...
I use the LA7200 with a Nikon D90. I find the widest I can go before I see the edge of the anamorphic is 20mm. It shows up when I use an 18mm zoom lens. I figure the angle of view = to 16 or so mm is pretty good for a wide IMO. These rules should apply to your FS100 since the sensor is almost the same size (with in a mm or so).
Good luck.
