FS: XHA1, EWA-Marine Bag, Red Eye + More!
V10TDI
Camera + Extras & CP have SOLD!
Now I need to sell the EWA-Marine bag, Kata rain cover and Redeye wide angle!
I live in the Orlando, Florida area.
Here's what I am selling (if it's not listed here, it's not included):
1. 72mm Red Eye .7 Wide Angle (non-zoom thru) + leather case: $350, normally $400
The Red Eye is about the size of a filter and weighs less than 100 grams. The bulk and weight have been eliminated by using a durable and compact, high index, high clarity optical material which substantially reduces the size and weight of the lens. Multi-layer anti-reflective coating to increase light transmission to near 100% for optimum image clarity, contrast and sharpness. In addition, hard coatings offer an extra degree of scratch resistance and improve water repellency. The lens housing is anodized aluminum and uses standard 72mm thread mount.
2. EWA VXA Marine Bag + carrying case (used once in my pool, didn't need it in Hawaii): $500, normally $550
The VXA is the 10 meter depth housing for the Canon XH-A1 and XH-G1 digital HD camcorders. Designed specifically for these camcorders the model VXM housing is manufactured from double laminated PVC and has an integrated, optically neutral flat glass port. Perfect for snorkeling or shallow diving, sandy, dusty, humid or foul weather conditions this housing will give your camera the best possible protection whilst being fully operable. It has a pair of non-corrosive and seawater resistant clamping rails which fit together for perfect sealing. They tighten by means of knurled thumb screw knobs. The straps at the bottom allow weights to be attached for perfect buoyancy under water. It is supplied in a handy yellow carry-case which has a water-proof interior and zippered side-pocket. Includes:
* yellow carry-case which has a water-proof interior and zippered side-pocket
* manual for ewa-marine video housings
* initial supply of CD5
* foam padding
* CAF ring with 72 mm filter thread adapters
Bump for the weekend.
If no one is interested in the entire package, I'll break out the individual parts.
