FS: Used Teradek RT Full Wireless FIZ Kit
wlyll
For sale is a used complete Teradek RT Wireless Lens Control System kit, ready for professional production use. This system provides full wireless control of focus, iris, and zoom, making it ideal for high-end cinema workflows across cameras from RED Digital Cinema, ARRI, Sony, and Blackmagic Design.
It comes with everything listed and is fully functional, production ready setup with all original components, mounting hardware, marking discs, power accessories, cables, and storage case included, everything needed to operate a full wireless focus, iris, and zoom workflow. This kit is perfect for cinema operators, focus pullers, or production companies looking to streamline workflow and achieve precise, repeatable results on professional sets.
What’s Included:
Core System
  • 1 × RT CTRL.3 Three-Axis Wireless Lens Controller
  • 1 × MDR.X
  • 3 × MOTR.X Motors with 15/19mm rod clamps
  • 3 × Quick Release Motor Clamps (15/19mm)
  • 1 × TOF.1 Precision Infrared Laser Range Finder
  • 1 × Receiver Rail Clamp (15/19mm rods)
Marking Discs
  • 6 × White Disc Type B
  • 1 × White Disc Type B Pre-Marked – Iris Ring 1–32
  • 1 × White Disc Type B Pre-Marked – 3m minimum focus
  • 1 × White Disc Type B Pre-Marked – 2m minimum focus
  • 1 × White Disc Type B Pre-Marked – 1m minimum focus
  • 1 × White Disc Type B Pre-Marked – 0.5m minimum focus
  • 1 × White Disc Type B Pre-Marked – 0.25m minimum focus
  • 1 × White Disc Type B Pre-Marked – 10ft minimum focus
  • 1 × White Disc Type B Pre-Marked – 6ft minimum focus
  • 1 × White Disc Type B Pre-Marked – 3ft 6in minimum focus
  • 1 × White Disc Type B Pre-Marked – 20in minimum focus
  • 1 × White Disc Type B Pre-Marked – 10in minimum focus
Iris Control
  • 1 × RT-CTRL Iris Strip Slider 0 (1–22)
  • 1 × RT-CTRL Iris Strip Slider 10 (1.4–22)
  • 1 × RT-CTRL Iris Strip – Blank
  • 1 × RT-CTRL Iris Strip Slider 30 (2.8–22) A
  • 1 × RT-CTRL Iris Strip Slider 20 (2–22) A
Mounting & Accessories
  • 1 × RT Monitor Bracket for Hand Controller
  • 1 × Controller Neck Strap
  • 1 × Thumb Screw (1/4”-20, plastic head, 1.25” length)
Power
  • 2 × LP-E6 Duracell 1600mAh Li-ion Batteries
  • 1 × LP-E6 Battery Charger
  • 1 × Power Cable ST-DTap (40cm)
Cables
  • 1 × RT Motor Cable ST-ST (16in / 40cm)
  • 1 × RT Motor Cable ST-ST (8in / 20cm)
  • 1 × RT Motor Cable ST-ST (23in / 60cm)
  • 1 × RT Motor Cable ST-ST (23in / 60cm, right angle)
  • 1 × RT 703 Bolt CTRL Plug (5-pin to 5-pin)
  • 1 × SmallHD Monitor Interface Cable (5-pin to USB Micro, 16in / 40cm)
  • 1 × SmallHD Monitor Interface Cable (5-pin to USB Type A, 1m)
  • 2 × 2-pin to 2-pin (Alexa) cables (18in / 46cm)
  • 1 × Wired Mode Cable (5-pin, 2.0m)
  • 1 × MDR.X ARRI R/S Cable
  • 1 × MDR.X RED CTRL Cable (16in / 40cm)
  • 1 × MDR.X Sony Cine R/S Cable (16in / 40cm)
  • 1 × MDR.X LANC Cable (40cm)
Additional Items
  • 2 × 2.4GHz Antennas (rp-sma)
  • 1 × Peel-off China Marker (for blank rings)
  • 1 × Vinyl Zipper Bag (250 × 150mm)
Storage
  • 1 × X-Large Hard Case (Black) with custom foam for RT CTRL.3 system
The price is $5500 shipped. Feel free to reach out with any questions or if you’d like additional photos/video, thanks.
