FS: Sony PVM-8044Q color monitor 16:9
dffiorito
SOLD!!!!!For sale is a Sony PVM-8044Q color monitor with AC power cable, two 25' BNC cables and Anvil carrying case.
Features:
  • High resolution 8-inch Trinitron CRT provides 450 TV lines horizontal resolution
  • Component input (Y/R-Y/B-Y or RGB), Y/C input and composite inputs for convenience and versatility
  • Pulse cross and Blue only modes
  • AC, DC and battery (two NP-1B batteries) powered for field operation
  • 19-inch EIA standard rack mountable (with optional MB-507)
  • Compatible with NTSC, PAL, SECAM and NTSC4.43
  • The PVM-8044Q picture aspect ratio can be selected between 4:3 and 16:9 depending on the input signal.
  • In the Underscan mode the picture size is reduced and the entire active picture is displayed on the monitor. This facility allows picture edges to be observed.
  • The Blue only mode monochrome display allows easy VTR noise inspection and chroma/phase adjustment.
  • Bias and Gain control volumes are accessible on the front panel of the PVM-8044Q. Fine adjustment of white balance can be easily done from the front of the monitor.
  • Frequency Response: 6.0MHz (-3.0dB)
  • Composite: Loop-through BNC1.0Vp-p, sync negative,Automatic 75 Ohms termination
  • Audio power output: Monaural, 0.5W with built-in speaker
  • CRT Type: 9" HR Trinitron Tube, visible picture, size 8" measured diagonally, 70° deflection, AG pitch 0.25mm
  • RGB/Component: Phono -5dBu, high impedance
  • External sync: Loop-through BNC4Vp-p negative,Automatic 75 Ohms termination
  • Power Consumption: AC: 43W DC: 40W
  • AC: 120V*20.7 to 0.4A, 50/60Hz
  • Dimensions W x H x D: 8 5/8 x 8 5/8 x 14 inches
  • Weight: 17lbs 3oz
  • DC: 12V 3.7A
  • DC: XLR 4-pin
The monitor, cables and Anvil case are all like-new and in great condition. I bought the monitor three years ago for about $900 and the case for about $300. BNC connections on the cables are solid with no tears or kinks. Monitor screen is perfect, no scratches, no blemishes to the body or rear connectors.
This is perfect for standard def work or a director/client monitor. I've used it for HVX 720P work and it's been great, but it is not a high-def monitor.
Asking price for the whole package is $700. I am located in New York City. Cash or certified check in New York City or PayPal if shipping to other locations. I haven't priced out shipping costs yet but I can provide that info upon completion of sale. PM me if interested. Thanks for looking!!
