morgan_moore
Major Contributor
I am talking FS7 here.
Various bloggites, members etc are pushing for NR in EI mode.
Of course if it is switchable off I don't care if it is added as long as the image is kept 'pure'
But seriously I think if you are getting noise from this camera today you are..
-exposing incorrectly
-shooting in a coal hole
I would encourage you all to do your own tests..
1) set a 'normal' shot - maybe a person holding a grey card lit with a single kino or CTB corrected readhead
2) light it to expose as you think for is correct for 5.6 (aka vary the distance of the instrument from the subect)
3) shoot the scene at 11,8,5.6, 4, 2.8
4) take all shots and equalise them in your grading suite aka if there is a grey card in the shot vary the 'development' until each card sits at the same level.
6) evaluate noise
I bet the 2.8 or 4 shot is super clean.
Firstly - no one wants to hire a camera op with a 'noisy needs a load of post work' camera. If you have bought the camera sustaining the noise myth shoots yourself in the foot.
So the F4 shot is clean? What does this mean? well a load of stuff about LUT implementation (Id love luts on Custom) and various other things that may impact your post workflow like using an 'ettr or T-1' LUT
Should you use CBrowse/EI then all that is handled.
IMO there are better things to pressure Sony for.
If a DP uses phrases like 'I have never been a paint by numbers shooter," etc then the camera is probably some missing some LUT management (in pre and post) to force them to shoot clean - currently the camera has to be painted by numbers - do I like this? - no - but scaring everyone with tale of noise wont change that - campainging for good LUT management and EI choice sustain in non sony software will.
I consider the 'thick negs' from these two tests to be free of noise, with no noise reduction in camera or post.
My equalised images. only noisy on the 'thin' exposures.
https://dl.dropboxusercontent.com/u/33167160/Mugshot-jpg12.jpg
https://dl.dropboxusercontent.com/u/33167160/ei.jpg
6) evaluate noise
