FS: NEW Editing Hard Drive Enclosure 4-Bay
ChippewaRewind
I've been a member here for a while but mostly read and rarely post. I have 100% positive feedback that you can check out on eBay if you need reassurance:
http://myworld.ebay.com/silvastratus
[FONT=Arial, Helvetica, sans-serif]This is a 4 Bay Hot-Swappable TRAYLESS SATA Enclosure w/ 4 eSATA connections and necessary cables included. It is the perfect editing solution for users that store a lot of data on multiple raw SATA drives. Simply open the door and the drive ejects, put a new one in and it mounts up immediatly. I was going to use it with my HVX because of all the High Definition football footage that I accumulate in one season, but the University bought one of their own. Now I have 2 :huh:
Here's the factory documentation:
[/FONT]
  • Terrific solution for creating a super fast external striped (RAID 0) SATA RAID array
  • Compatible with all 3.5" SATA I (Serial ATA 1.5Gb/s) and SATA II (Serial ATA 3Gb/s) Hard Drives
  • Tray-less drive mounting for fast and easy drive swapping
  • Store large amounts of data at ultra fast data transfer rates of up to 300 MB/s
  • Built-in universal 80 watt power supply
  • Super small footprint
  • Platform independent—works with any computer having a compatible SATA controller
  • Includes 4 eSATA cables
This 4-Bay SATA external enclosure is built for speed and convenience! With 4 eSATA connectors (one for each drive) your data passes straight from each drive to the SATA host controller with no "bridge chip" to slow the transfer. Super convenient enclosure design includes tray-less drive bays which require no screws for mounting your drives. No drive mounting screws, no drive trays! Putting in a drive is as simple as opening the bay door, sliding the drive in, and then closing the door. And the drive bays support up to 50,000 insertion/removal cycles!
Compact design with a powerful built-in universal power supply. A great solution for anyone looking to store large amounts of data in a little package.
Fill the enclosure with four 1TB SATA drives to create a monster 4 terabyte striped RAID array for uncompressed HD video capture and editing! Or start out with a single drive for simple data storage and then add additional ones as the need arises.
What's In the box:
  • External 4-Bay Hot-Swap SATA Enclosure (see picture)
  • Four 2 meter eSATA data cables (see picture)
  • Hard Drive Rack Keys
  • Quick Installation Guide
  • AC power cord
Specifications
  • Connectors: Four eSATA connectors
  • Compatibility: Compatible with all 3.5" SATA I (Serial ATA 1.5Gb/s) and SATA II (Serial ATA 3Gb/s) Hard Drives
  • Drive Mounting: Tray-less drive bays require no screws and support up to 50,000 insertion/removal cycles
  • Performance: Up to 300 MB/s
  • Power Supply: 115/230 VAC, 50-60 Hz 80 watt
  • Dimensions: 7.2 in. x 7.2 in. x 16.0 in.
  • Weight: 16 Lbs
  • Warranty: One Year Manufacturers Warranty
Here is the site I bought it from:
http://www.cwol.com/serial-ata/sata-ii-4-bay-enclosure-sbox-4e.htm
I shopped for months and it was the cheapest solution I could find. However I am willing to loose a little money to avoid loosing more in the long run. I will let it go for $200 shipped.
Contact me if you have questions!
