JasonFox
Internet Sensation
I am the original owner and the unit has always been in a smoke-free home studio. All buttons/functions work as they should.
This comes in the original box with the original manual for the 828 and the included AudioDesk 2 software. The CD with AudioDesk and the unit's drivers is included, but you'll have to download new drivers and and a new version of AD direct from MOTU -- I know the drivers on the disc won't work on an Intel Mac. But you'll probably need to install AudioDesk off the CD in order to update it. If you're using this with something besides AD (which is what I did), then you'll just need the most recent drivers for your particular system. I'm also including a FW cable that is not in the photos.
MOTU 828 MKII info:
• CueMix DSP™ near-zero monitoring system.
• Front-panel control - access your entire mix, or any 828mkII setting, directly from the front panel.
• Stand-alone operation - program your mixes at the studio and then bring the 828mkII to your gig - no computer needed.
• Need to tweak the mix? Do it on site using the back-lit LCD and front-panel controls.
• Multiple CueMix DSP mixes - create different monitor mixes for the main outs and headphones.
• Add send/return loops for outboard gear - with no latency.
• Two mic pre-amps with switchable 48-volt phantom power, front-panel trim controls and pre-amplified sends.
• Mic/guitar instrument sends - add your favorite outboard EQ, preamp, reverb or other processor to the two mic/guitar inputs, before the signal goes digital.
• 20 inputs / 22 outputs - there's no channel sharing in the 828mkII; the mic inputs, S/PDIF I/O, headphone out and main outs are all handled as separate channels.
• 8 channels of 24-bit ADAT optical input/output. Eight channels at 44.1/48kHz. Four channels at 88.2/96kHz.
• Sample-accurate digital transfers between ADAT digital tape decks and the computer via the ADAT sync port.
• Sample-accurate MIDI - connect a MIDI controller and/or sound module with no separate interface needed.
• MIDI I/O is sample-accurate with supporting software.
• Expandable - add additional interfaces for more I/O as your needs grow.
• Eight 24-bit 96kHz analog inputs and outputs on balanced/unbalanced 1/4" TRS jacks
• Separate TRS main outs and front-panel headphone jack, each with independent volume control.
• Stereo 24-bit 96kHz S/PDIF in/out
• Word clock in and out
• SMPTE in and out
• Includes drivers for Mac & PC, including ASIO, WDM, Wave, GSIF, Core Audio, and Core MIDI.
• Supports all popular Macintosh and Windows audio software.
• 100% compatible with all host-based effects processing in today's popular audio programs.
• Plug-and-play operation with your Mac or PC via high-speed USB 2.0.
• Front panel volume control for main outputs.
• Front panel headphone jack with independent volume control.
• Front panel meters for all analog, digital and MIDI I/O, plus SMPTE sync tach and lock LEDs.
• Dedicated front panel clock status LEDs.
More info can be found here: http://www.motu.com/products/motuaudio/828mkII
Pics here:
http://jasonfox.net/StudioGear/JFox_StudioGear_06.jpg
http://jasonfox.net/StudioGear/JFox_StudioGear_07.jpg
http://jasonfox.net/StudioGear/JFox_StudioGear_08.jpg
$325, Paypal prefered, free shipping in US; will consider international shipping to established DVXusers.
Thanks.
MOTU 828 MKII info:
• SMPTE in and out
Pics here:
Thanks.
