Manhattan LCD 8.9" HD Pro Monitor HD089B with sun hood, remote, A/C supply, small HDMI cable. $225 PayPal shipped CONUS
I used this on my jib for framing and focus, probably no more than 20 times, but have switched over to SDI. Color is not the most accurate, but useful nonetheless as an under 2 lb. monitor for general viewing
There have been 2 mods performed on this unit
#1-There is a regulator on the back of the lcd screen-you can change the dip switch settings so that #6 and #3 are on this will overdrive the led's by 50% which will make it a bit brighter.
#2-While I had it open, I rotated the housing 180 degrees around the electronics, because the bottom thread was slipping in the housing, (pic shown) so now they are on top and "new" threads are on bottom.
Original info can be found here:
http://www.manhattanlcd.com/product_p/7005.htm
8.9” LCD WXGA (1024x600)
HDMI-1 Input, Supports 1080p, 1080i, 720p, 576p, 576i, 480p, 480i
12 User Presets, Brightness, Contrast, Saturation, Tint, Sharpness, Gamma, RGB Color Temp, 16:9, 4:3, 16:10, 15:9, 1:1, 1.85:1, 2.35:1, H + V Position, Over/Under Scan, Auto, Freeze Frame, PIP, PBP, On Screen Display, Multi Language, Infrared Remote Control, OSD Timer, Sleep Timer, False Color, Blue Gun, Monochrome, Color Bars, Screen and Aspect Markers, HDMI Color Space (Auto, 709, 607, RGB)
