FS: Manfrotto 516 Fluid Head
vongspoth
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170430443141&ssPageName=STRK:MESELX:IT
I've switched from a Panasonic HMC150/Letus Extreme/Zacuto Rails to a Video DSLR so I don't need something so heavy duty (it supports up to 22 pounds!). This tripod head has been a dream to use and works perfectly. It was purchased last year and has been used gently. There is a cosmetic blemish on the tilt knob. The thin plastic cap has a cut in it, but it hasn't affected performance in any way.
Items:
Manfrotto by Bogen Imaging 516 Pro Video Fluid Head
Quick-Release Camera Plate (#3272)
2x Pan Bar Handles
Product info:
The Manfrotto 516 Pro Video Fluid Head is specifically for the latest DV camcorders used by documentary and industrial videographers, and can support cameras up to 22 lb. Equipped with fluid cartridges, which provides continuous adjustable drag control. This system gives quite a wide range of friction control down to "zero drag" and operates on both pan and tilt axis. Other features include separate pan and tilt locking mechanism, a fixed counter balance spring of 16.5 lb load capacity at a center of gravity of 5-inches and a built-in bubble level.
• Continuous adjustable pan and tilt friction knob (from 0 to max level)
• Separate pan and tilt locks
• Sliding quick-release plate
• Built-in leveling bubble
• Maximum payload of: 22.0 lb
4 Days Left Bump. By the way, this is the fluid head that I upgraded to from a Manfrotto 501 because of the additional weight from the Zacuto baseplate and Letus adapter I was using. Tilting became much easier with the 516 and very difficult to perform on the 501.
3 Days Left Bump. I just received a PM from another member who's looking to upgrade from the 501 fluid head:
"I have the 501 head at present and have just bought a M2 and the current head really is not up to the job."
Also, for those that may not be aware the 516 has true fluid cartridge's where the 501 and such use friction discs. So that makes this a true fluid head.
I just had a look at the photo's on eBay. Is the cosmetic blemish and slight cut that you refer to in the last photo on the right. I can't see any other marks and infact the unit looks in mint condition other than that very small cut.
Yep. The last picture is a close up of the cut. It's a plastic like sticker. That's the only issue it has. Other than that, it's almost mint.
I own one it's great! So smoooooth but I need the same quick release plate for my glidecam anyone know where I can make this work
