[FS: Optics] FS: Leica R Duclos CineMod 6-lens set, $7650
cscherf
Beautiful set of Leica R primes, calibrated and modified for cinema use by Duclos Lenses.
https://www.lensfinder.com/listings/leica-r-duclos-cinemod-6-lens-set
Duclos is highly regarded in the film industry for its lens modifications and service. This set generally centers around the Elmarit f/2.8 versions of each lens with the exception of the legendary 50mm Summicron f/2. In some instances, a good case can be made that the Elmarits are optically superior to the more expensive Summicron and Summilux lenses (IE: the 90mm), and with today's digital sensors, wider apertures are often unnecessary. Leica R lenses are a great option for modern cameras, given that they can cover a full-frame sensor, are adaptable to different lens mounts, are light and compact but built like a tank, and offer a creamy, painterly, “Leica look” that compares favorably to Cooke cinema lenses but with a much more affordable price tag.
The set includes these lenses:
19mm Elmarit f/2.8 Version 2. Serial: 3504907
Widely regarded as one of the best wide-angle lenses ever made, this is the much sought-after Version 2 of the 19mm. Includes the 80mm front ring and press-on lens cap by Duclos.
Condition: 9/10 Cosmetically only few light signs of visible use/wear to the finish. No dents, dings or scratches. Optically clean and clear. No scratches, dust, or fungus.
28mm Elmarit f/2.8 3 Cam Version 1. Serial: 2828556
Condition: 8/10 Cosmetically only few light signs of visible use/wear to the finish. Missing the plastic Leica red dot (cosmetic only). No dents, dings or scratches. Optically clean and clear. No scratches, dust, or fungus. Comes with original bayonet-mount front hood. NOTE: No front lens cap, due to the hood.
35mm Elmarit f/2.8 3 Cam Version 2. Serial: 2929067
50mm Summicron f/2.0 Version 2. Serial: 3412547
60mm Macro Elmarit f/2.8 3 Cam Version. Serial: 3423753
Condition: 8/10 Cosmetically only few signs of visible use/wear to the finish. Missing the plastic Leica red dot (cosmetic only). No dents, dings or scratches. Optically clean and clear. No scratches, dust, or fungus.
90mm Elmarit f/2.8 3 Cam Version 2. Serial: 3384825
Here’s what you get with the Duclos Cine-Mod:
Aperture De-Click / Dampen
Aperture de-clicking is a vital part of the Cine-Mod. A true cinema lens features a step-less aperture that allows fine adjustment without "clicking" between f-stops. Duclos Lenses modifies the aperture movement by removing the "click" mechanism and damping the movement to create a consistent, creamy rotation. We use a high-quality lubricant to ensure a professional feel and operation of your lens.
Focus Gear
Our seamless 32-pitch (0,8 module) focus gears are precision machined from solid Black Delrin®, tailored to each lens individually in-house to ensure a no-slip, non-binding reliable fit. Every gear is machined and installed by a skilled technician on an individual basis to ensure a lifetime of accurate operation. No zips, clips, or 3D prints from Duclos Lenses!
Canon EF/EOS Mount
Professionally installed and calibrated mounts, made by Leitax. Can mount to any Canon EF camera.
Finally, I’m including protective cases for each lens by Ape Case, Hoya Pro-1 Digital UV filters, and front and rear lens caps, unless otherwise noted. These lenses have been gently used by a professional and stored in dust-proof cases and climate-controlled environments.
