Price $299. $35 shipping. Up front payment by Paypal, or cash in person. References available. Contact Stephen D. Weller at arrisw@msn.com Hampton, NH
The TMH150CGU 15" Color Production Monitor is a very high performance broadcast monitor with 750 lines of horizontal resolution. The monitor has an all-metal case, is widescreen and 4:3 switchable and auto detects both PAL and NTSC systems. It even has a built-in speaker. Standard from the factory the monitor will accept composite and S-Video inputs. The unit also has an expansion slot for cards that add analog component ins and outs and digital SDI ins and outs.
This unit has a blue gun setting for exact calibration. It is a high resolution SD monitor that can be used with DV, HDV, or HD if downscaled. Final Cut Pro 6 and 7 will display HDV in widescreen over firewire, output to S Video or RCA inputs with realtime playback from the timeline using this monitor. Exact color correction capability in an affordable pro package.
The monitor is in excellent like new condition with about 30 hours of use on a few selective editing projects.
Superior Resolution
The TM-H150CGU is a very high resolution monitor that is more than capable of displaying its standard composite and S-video inputs. When the expansion slot is used for analog component or uncompressed SDI, the unit shows all that can be shown, adequate for almost any edit suite or production location.
Switchable Aspect Ratio
The monitor will display naturally widescreen 16:9 elements as well as conventional 4:3 video. The TM-H150CGU is ready for widescreen production.
Front Panel Operations
Changing color or other standard picture-look parameters can be accessed right from the monitor's front panel. Phase, Chroma, Brightness and Contrast control are all just a push-button away.
Remote
A D-sub 15-pin connector is built-in to provide the user with the ability to select and change aspect ratio, input source and toggle between overscan and underscan with RS-232C.
What's in the BoxJVC TMH150CGU 15" Color Production Monitor
in original box.
Superior Resolution
Remote
in original box.
