[FS: Optics] FS: Iscorama 54 MC with accessories
prio
Iscorama 54 mc w/ front and back lens caps (near perfect / mint condition. no scratches, haze, fungus in either the front or back element.
There is a small spec in the corner of the front lens. i cant tell what it is whether its inside or outside the glass.
in either case, even if you vignette, your camera will never catch it.
Also no dents, has some slight marks on the body. I consider the body 9/10.
The focus ring is also smooth. it has less resistance compared to other iscoramas ive handled.
Tiffen 4-1/2" 1/2 Diopters
2x Seamless follow focus http://www.ebay.com/itm/Seamless-Fo...574?pt=LH_DefaultDomain_0&hash=item3cecafee6e
Tiffen Professional 95SSLR 4 1/2 (4.5) Adapter Ring
http://www.ebay.com/itm/Tiffen-Prof...532?pt=LH_DefaultDomain_0&hash=item33857267ec
you will need this Tiffen 4-1/2" Retaining Ring in conjunction with the adapter ring in order to use the Tiffen Diopter/
http://www.ebay.com/itm/261635681138?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Tiffen Professional 95c Clear UV Filter (this has scratches, this is more of a protective shield when not in use)
77mm back (screw-in adapter)
s&W Photo accessory co. 95mm to 86mm adapter
95mm to 82mm adapter
vivitar series diopter 86mm close up filter +1 +2 +4 10x (macro)
Comes with a Kowa case.
I prefer to deal with a buyer in person. Im in the So cal area.
asking $3500
I can give you names on other members on here and bmcuser as well that i've had transactions with.
thanks for looking.
