FS: Bogen Manfrotto 516 Head and 161MK2B Legs
bbass74
Pics at : http://nashville.craigslist.org/pho/1407786141.html
Asking $800 for both.
For sale: Used Bogen Manfrotto video tripod system.
Manfrotto by Bogen Imaging 516 Pro Video Fluid Head (Quick Release) - Supports 22 lb:
The Bogen/Manfrotto 516 fluid head is specifically for the latest DV camcorders used by documentary and industrial videographers, and can support cameras up to 22 lb. Equipped with fluid cartridges, which provides continuous adjustable drag control. This system gives quite a wide range of friction control down to "zero drag" and operates on both pan and tilt axis. Other features include separate pan and tilt locking mechanism, a fixed counter balance spring of 16.5 lb load capacity at a center of gravity of 5-inches and a built-in bubble level.
• Continuous adjustable pan and tilt friction knob (from 0 to max level)
• Separate pan and tilt locks
• Sliding quick-release plate
• Built-in leveling bubble
• Maximum payload of: 22.0 lb
Manfrotto by Bogen Imaging 161MK2B Super Pro Tripod Legs (Black) - Supports 44 lbs (20kg):
The Manfrotto 161MK2B Super Pro Tripod is the tallest in the Manfrotto line of tripods, and is capable of supporting cameras up to 44 lbs (20kg), at a height of over 8.5' (2.6 m). It is the ideal large format tripod for home and studio use, and works especially well with the 160 (3057) Professional Head.
The 161MK2 offers a working range from a 17.3" minimum to a maximum of 105". The center column is geared for easy, accurate adjustment. This tripod can easily handle an 8x10 view camera even at full height and precarious angles.
Replaces old part numbers 3058 & 3258.
• The built-in mid-level spreader adds anti-torsional rigidity and stops the tripod legs from accidentally being knocked wider apart. Compared to a ground-level spreader or dolly, the mid-level spreader has the advantage that it stays well out of the mud and dirt and is more suitable for use on uneven terrain.
• The geared center column allows for safe and precise height adjustments.
• The three set screws in the camera platform can be used to permanently secure the head to the tripod, providing additional security.
• The twist locks are slightly slower to use than the more common "Quick Action" flip lever leg locks, but give total control over locking force. In addition, they are much easier to service out in the field.
