FS Bogen 3191 tripod with 3066 head
sunporchmedia
SOLD
Bogen/Manfrotto 3191 tripod with 3066 flluid head.
Currently my backup for my HVX200. I've used this setup with a DVX100, up to an HPX500 and it delivers nice smooth shots. It would be great for a DSLR rig or lightweight camcorders. Perfect if you need excellent performance without spending thousand$.
Sticks:
Description/features: Silver aluminum with rubber feet with retractable spikes. Self-locking design eliminates the need for spreaders. Lever locks offer easy, solid locking. 100mm bowl. Maximum load: 44lbs. Extended height: 59". Retracted height: 36". Folded height (without head): 39".
Condition: good used condition. Everything is tight, solid and operates as it should. Rubber feet are in good condition. Normal wear and tear (scuffs and scratches). Only fault is that the integrated bubble level is broken (I level by eye or use a cheap hardware store level)).
Head:
Description/features: This is the older version of the 3066 design. Rated for cameras up to 22lbs. Adjustable fluid pan and tilt drag. 100mm claw ball. Note that this design doesn't have spring counterweight, so ordinary care must be taken to lock the tilt when walking away from the sticks. Includes two pan handles (second one not pictured). 1/4" and 3/8" (not pictured) camera screws included.
Condition: excellent used condition. I have replaced the cork gasket that the camera sits on. Everything is tight and functions as it should. The second rosette for the left pan handle is not pictured but is included and I will attach it before shipping.
SOLD -- To me! Arrived very well packaged, excellent condition. SunPorchMedia is a awesome seller with great communication!
