[FS: General] FS BARTECH BFD remote focus double set, extras
vinc
Upgrading to 3 ch. system so selling my beloved analog double Bartech set:
2 focus transmitter handsets (S/N T1.2206, T1.1020)
2 receivers with angled antennas (S/N R1.1746, R1.1020) both have just been in for repair/service by Jim Bartell
M-one motor (S/N M-1.0585) with 15mm insert, 6 gears, dogbone bracket with 15 mm insert
Heden M28VP motor (S/N 20483) with 15mm insert, 4 gears - as new as just serviced by Heden with new int. motor, ballcage/-races
14 alu marking rings from Louis Puli - Customized!: both handsets have been modified with a pin from a FF4, rings have an extra hole milled into the side, so most simply snap on and stay snug, though a couple still need to be fastened with a screw (or simply tape)
Modification done by a very skilled mechanic, rings and mod worth alone over $ 1000
cables:
6 motor cables various lengths, 2 have an angled plug on one side
Arri RS power/run Y cable
F5/55 run
Aaton power and run
Sony ENG run
D tap to XLR power
2 XLR to BFD receiver power
jumper cable, power through to second receiver
Set of 4 iPowerUS rechargable 9V batteries for handset, charger, 220v EU cable, car lighter cable (one battery lasts you several days)
2 Pro sled bracket
Manfrotto bracket
Carry strap
spare parts, antennas, power switch, lemo plugs (motor), lanyard post, rubber strips
Case
All in good working order, normal signs of wear.
Asking $ 8000 plus shipping, Paypal or direct bank transfer accepted.
Based in Amsterdam, Netherlands
