FS: Arri 15mm LW Single Sided Follow Focus
Macville
I have a Arri Single Sided Follow Focus for sale. It the pre LFF-1 model that was used on many 16mm and 35mm cameras when a very small FF was needed.
The follow focus is in pretty good condition and has about 1.5-2mm of play (seems to be pretty standard for this model as all the ones I've worked with before were the same). It's be relubed and cleaned. It's fitted for lightweight 15mm and works great on the RED 15mm adapter.
This follow focus is great if you have smaller prime lenses like the Ziess Standard/Super Speeds, or a smaller barrel zoom lens. Also great for video cameras as it comes with a gear that will work on Fujinon and Cannon lenses.
It comes with
the Follow Focus
3 arms - A16 BL/A 35 BL arm, A 16 SR arm, & A 35 III arm.
1 video gear that can be put on the A35 III arm with 4 small screws and a little big of glue if you want.
2 - Magnetic marking discs.
Note: One of the tightening screws is missing from the pictures, but I do have it and it will be included.
I have found this FF here in the US for around $1200 and in the UK for $1000. Asking price is $700 + $10 shipping.
Matthew
Pictures:
