FS-100 and 24N
ajmax
If i understand this correctly, in order to use the under /over cranking it needs to be done in the 720 24PN mode. If that is correct , The FS-100 cannot record that because the 720 24PN mode does not go out the 1394 connection...
Is that correct???
The why does the new firmware for Fs-100 V3.0 say that it can record 24N???
I thought it was the HVX 1394 connection that does not allow the N mode to go through?
If this is the case, how can I get the variable frame reates without a P2 card? I just bought my HVX and my 8GB P2 rebate card hasn't gotten here yet?
Ray
1- Shoot 720p24, use whatever alternative frame rate you need in the Scene File.
2- Import without using the advanced pulldown removal in the FCP P2 Import window.
3- BEFORE placing in a Sequence, use the DVCPRO-HD Frame Rate Converter to conform it to the editing time base of your Sequence.
4- Place in Sequence, it'll give you the over/under cranked effect you shot in-camera.
on the frame rate converter , what do I check?
I see there are 3 different check boxes..and which frame rate do I select if for example I shot in 48fps?
And, does this simulate the under/over cranking being FCP version
or will this give you the exact effect that the HVX does when shooting native to a P2 card?
Thanks,
Ray
If your sequence is set to 24p, then it would be the 23.98 checkbox.
I do this all the time with or without the FS-100.
Remember that the alternative frame rate in the scene file is also related to what frame rate you have set for capture.
I see. I am trying to shoot 720 24p with the frame rate set aat 48fps..
I don't recal seeing 48fps in FCP capture , Sequense and Frame Rate Converter...
ajmax said:
Hey Ben,
In Frame rate Converter, I didn't see 48fps as a choice..
Because there's no real 48fps editing time base. You're going to be editing in a Sequence that's either 60, 30, or 24 fps, not 48fps.
I shoot 720p24, VFR of 60. In FCP I'm editing with a 24fps Sequence. My slow motion shot is 720p24 VFR-60. So I tell the FRC to conform that clip to 24fps. So when I put it in my 24fps Sequence, the frames are spread out to comform to my editing frame rate base.
Here's the PDF from the FCP on-line help files. You can find in it FCP by going to help and searching for Frame Rate Converter. But just to make it easy, here's the PDF itself.
http://www.bbalser.com/public/FrameRateConverterHelp.pdf
Thank you Ben
This is exactly what I needed to know !!!!!!
you're a master od knowledge!!!!!!
Have a good weekend...
Ray
Just for the record:
Wrong, it can be done in both a Native mode and non-Native 720p24 mode.
