Frozen GH1 monitor output from Final Cut
jeddv
I am in Europe so am shooting for a 25p output.
I have an external 17" HD CRT monitor running from a Blackmagic Extreme card.
Monitoring works fine if I shoot motion JPEG but if I convert AVCHD in Neoscene the image remains frozen on the screen until the clip stops, at which point the monitor image is updated. Any ideas on how to solve this?
I think I've tried all the Blackmagic pre-sets and nothing seems to work.
I don't think Cineform has support for video playback over Blackmagic cards. If you want to transcode AVCHD to Blackmagic codecs use Toast 10.
It's not the card. Cineform doesn't work due to proprietary nonesense from Apple not supporting non native codecs for video preview.
If you go to the Neoscene website, the workflow they outline is
1) make your cineform version
2) drag it onto a proress timeline
3) render
4) now you can edit and preview and add effects as if you were working with prores
5) for output, duplicate the sequence, change the codec back to cineform, output
Seriously. Go their website and that's what it says.
For this reason, since I only saw a very miniscule quality jump in cineform over prores, I just make prores versions now, not cineform versions. (Though it sucks to lose the smaller file size of the neoscene versions).
But I'm using Neoscene to make ProRes HQ files...
Shouldn't that work?
Yes. that should work.
(with FCP, don't know about your card)
Also, check that you're actually getting ProRes out of Neoscene and not Cineform because the problem you are describing is exactly how FCP should not work with Cineform.
It's definitely ProRes and, it seems will play from the Canvas if I allow Final Cut to convert the file to the sequence settings but not from the Viewer. The weird thing is that the sequence settings are supposedly the same as the converted file so I'm not clear what conversion is going on. I've sent the problem to both Blackmagic and Cineform so will let you know what they say.
Also...maybe a dumb question but is it possible to get ride of the the four bits of text that appear on the converted clips saying: 'Cineform Intermediate Digital Master'.
Do you know it's prores because that's what you're selecting, or because you've opened the file in QT and hit command I or command J?
Still no go.
Still no go.
'Command I' in the Finder gives the file details as ProRes, 25fps.
For a little more info. I did as suggested in the Quicktime player which just confirms matters. Any ideas?
No idea.
Perhaps Martti nailed it on the first reply?
But if Blackmagic cards work with Prores it should make no difference from whence the Prores originated if it is indeed prores.
Jack,
this is interesting. I converted to ProResHQ in Neoscene. FCP recognizes it as ProRes but QT shows with Command I that it is Cineform.
Format: CineForm HD/2K/4K, 1920 x 1080, Millions
16-bit Integer (Little Endian), Stereo (L R), 48.000 kHz
Weird at least.
Uwe
intersting ...
Jeddy why don't you try bringing in a clip through log and transfer instead of Neoscene and see if there's any difference.
One more NeoScene bug then - looks like they've forgotten to change the meta tag for the ProRes encoding. Which might confuse the sh*t out of the Blackmagic card. The GUI bugs in NeoScene were enough to stop my from plunking down for it at once. Cineform clips look very good though for the file sizes so I might get it if I land a gig that will end up on a big screen.
Hey Martti,
I've been using neoscene for a very long project with no problem, btw. Hundreds of clips processed. You just have to make sure you have a good build and if they put up a crappy one in a rush, complain till they fix it or reinstall the previous build (which they leave up in case they make a boo boo with the new build).
Ok this is a stupid suggestion but you've hit command-f12 right? Your output is set to all frames not single frame? Or does this not even apply to using the blackmagic card/was the first thing you tried?
Yes, Ben_B I have been outputting all frames.
Anyway, it seems it is the Blackmagic card. This is the response from Blackmagic:
Hi Jonathan,
Thanks for your email. More often than not, this happens because the output
mode used does not match the footage. The card itself does not support
1080p25, so there isn't a 1080p25 mode on the list.
The closest setting would be the 1080i 25Hz (which is actually 50Hz) modes.
However these might not work either, as they are interlaced.
One other option that may possibly work, would be to edit the 1080i50 Easy
Setup, by changing the field order to 'none' (it's possible you may need to
change other options too), this may now work. But I cannot guarantee this.
We do intend to add further progressive 1080 format support on the HD
Extreme 3 card in the future, but as this time, the above methods may be the
only ways to display 1080p25 footage.
Regards
Chris Pearse
Technical Support Consultant
Blackmagic Design EMEA
So I had already tried all that before he got back to me. Anyone have any other ideas?
(My HDCAM 25p footage runs fine with the Blackmagic 1080i50 setting).
Cheers,
Jonathan
intersting ...
I also can't get log and transfer to work at all. Even when the 'private' folder is completely untouched I get the 'invalid directory structure...' warning and nothing is imported.
