Free-run timecode after S&Q
I used an FS700 for the first time this week on a shoot. I wanted to use free run timecode to sync 2 cameras plus audio. No jamming from a sync box, just set it once and leave it alone, then find the offsets in post. But I found that every time the FS700 goes into S&Q mode, it switches to record run timecode. Yes, that part makes sense, but the problem is: It doesn't switch back to free run when you go back to regular shooting. Which makes it totally useless for that kind of quick syncing. Is anyone else having this problem? I hope it can be fixed with firmware.
Does anyone have any insight into this issue? I have a post department ready to kill me and a director who doesn't want to wait to resync every time we go S+Q.
Yes I noticed that as well a long time ago. I just got used to it, I understand the technical reason for this, that does not mean it can't be fixed but it is complex.
If you go SQ then get used to re entering time and switch to free run, it is pretty quick. But I would definitely point it out to Sony, I did. Maybe in a future FW update, but don't hold your breath...
I am working with 3 FS700's, 2 hand-held and one on a jib on a show where we have talent come in for a limited amount of time. There is a constant switch between the S+Q mode and back to 30p. The problem with the operators switching back is that the TC is off once they switch back based on how long they were in S+Q mode and then the cams aren't on the same time. I have just started each camera by pressing the timecode button so they aren't perfect to begin with, but they go wild once S+Q mode is entered and returned from.
Now I don't have the cameras in-front of me but I'm wondering if there is a way to set the timecode to time of day, and set the time of day on each of the cameras within 1 sec of each other. Then at least as we switched back and forth, the times will resync closer than setting the timecode in preset. Now I will try tomorrow and report back. At least it saves the idea that timecode can be an accurate measurement of both the time of the shots and the duration between the shots.
My AC had the idea of setting one of the quick buttons to the timecode menu but the assign functions are very limited on these cameras.
Lots of little quirks with this cam, why does the info disappear from the HDMI and SDI feeds when any sort of marker is enabled?
Of course for what it is, the FS700 is a useful camera but I know the real answer for my scenario is getting the production to pay for F5's. The FS700 doesn't even have a timecode input besides recording onto an audio track, sony designed this for single shooters those looking to upgrade from their DSLR, the cinealta cams are for multi cam sets. Whats crazy is I also have a 5 year old sony handy cam from best buy with a high speed mode, this thing handles timecode more professionally than an FS700. It does seem like something that could be an easy fix in a firmware if sony has any development supporting the camera.
As an in-camera workaround, I've been setting the timecode mode to freerun and the seed to TOD. As everyone has noted, in S&Q mode, the freerun mode is suspended and you're returned to REC Run when you get out of S&Q. The only way I've found around this is to record to my Pix recorder and jam sync TOD. That does require an external recorder, but, that's the only way I've found to do this.
Anyone have an updated workaround for this?
And I'm curious if the newer FS5 does the same when in/out of S&Q mode... I have a feeling it does, but any first hand info or mention in articles would be great!
