Lill Creates:
i hear via a varicam shooter that the HVX can do frame rates less than 12fps.
allegedly you create a scene settings text file, on your computer, using the frame rate you wish to use (they have to be in even increments, i.e., 4, 6, 8fps) and then save it on an SD card and viola! the lower frame rate is there. is this true?
the other questions are:
has anyone done this?
will this create a technical (or even a warranty) problem for the HVX?
thoughts?
also, i searched the forums and i didn't find anything new on this.
thoughts?
