I have footage shot in DVCPROHD 720p60 on my FS-100, I'm trying to convert into 59.94 frames per second with the Final Cut Pro Frame Rate converter. My problem is that it does the conversion, but on the playback it plays it at the default frame rate from the HVX200 not the 60 frames or to the converted 59.94. Am I doing something wrong here with my settings?
The Item properties of my clip is as follows:
Vid Rate: 59.94 fps
Frame Size: 960x720
Compressor: DVCPRO HD 720p60
Field Dominance None
Alpha: none
Compoite Normal
What am I doing wrong here that won't let me get that coveted beautiful overcranked image?????
Vid Rate: 59.94 fps
Frame Size: 960x720
Alpha: none
Compoite Normal
