frame rate, DVD, Blu-ray, and magnetic fluorescent lights
I've studied this until my head hurts. Looking for a seasoned hand to show me the forest where I can only see trees. Or some similar metaphor. :undecided
This is in the USA (NTSC land). I'm going to be taping a class (single presenter in front of a live audience). The end target is both DVD and Blu-ray, with some web trailers on YouTube (or wherever). The class is taught in a huge room at a local college that has a ceiling full of magnetic fluorescent lights. I won't be able to overcome these lights with my own, so I'm basically stuck with them, flickers (60Hz), buzz, and all. The best they'll let me do is supplement a bit.
My question is, what frame rate should I use to capture the class? There doesn't seem to be a good "common denominator". Yet I know that people here deal with this situation on a daily basis. I'm leaning toward 30p, but I don't want to screw this up.
I'm thinking capture at 1080p30 because DVD wants 30i, Blu-ray supports 30i also, and web wants 30p. These should all be fairly easy for Adobe Media Encoder to transcode to without inducing any judder. Plus, if I use the "normal" 180 degree shutter (1/60 for 30 fps) I get a full cycle of light and no flicker.
Or am I missing something?
Well, I wrangled some test time on location. Turns out that as predicted, 1080/30p at 1/60 second works like a charm. No indication that the lights are fluorescent -- no flicker, no strobing, just nice even soft light. White balance took out almost all of the green spike, so it's a fairly easy color grade too. This was a surprise, but I'll absolutely take it.
About the only negative was from all the light coming from the ceiling -- it causes some little bit of shadowing that tends to play up the dark circles under everyone's eyes. We'll look into this; I suspect we can eleviate most of this with makeup.
Anyway, just wanted to post results in case anyone references this thread in the future. Who knows, someone might find it useful.
Technically, it's 60i, not 30i. But I would shoot 30p.
1080/30p, but you'd have to render out at 1080/60i to put it on a BluRay. This is not so bad, actually, because after the monitor puts the two interlaced frames back together, you're essentially viewing 30p anyway (assuming a recent monitor with fast refresh that knows how to do this).
- Greg
I am in a similar situation in that I have to be able to deliver Blu-Ray and DVD. However, I am shooting a dance recital. Weddings look great at 1080/30p, but I didn't know if the fast movement of dance would require otherwise. I shot this same recital last year using 1080/60i and the results on Blu-Ray were incredible. It took quite some finagling to convert it for DVD. It seems as if 30p is the way to go all the way around, but I didn't know if the fast motion would work better at a different frame rate. Most of my customers are going to be ordering DVD, so I want to make sure that the downconverted product looks as good as it can. I should mention that I have an AC160 and i can now shoot at 1080/60p. My version of FCP 6 will not support it without converting using Voltaic or some similar product. I think it may be dumbing it down anyway. Any suggestions??
