MDKfilms
I just wanted to give a setup suggestion, for what its worth, may not be for everyone but it works for me for now. I wanted a quick way to go from 12fps to 60fps so what I did was setup my scene files with the different fps dialed in. Now all I have to do is turn the scene file nob and I can go from 12 to 60. Understand that not all speeds are represented, you have to choose which ones you want or which ones you use most often. It is a very quick way to shoot different fps. Also all other scene settings should be the same, a little draw back perhaps but once you have your look dialed in for a particular shoot just save to SD card and when needed upload back to camera. Is there anyone else doing this? Just my two cents.:nads:
