Is there a way to format P2 cards on a Mac?
I have a MacBook Pro with the DuelAdapter, and have been offloading files from P2 cards onto two external firewire hard drives during shoots. As other folks have mentioned both on and off DVXuser, it can take some work to erase all of the contents of the card after copying the footage off of it. To get the LAST CLIP.TXT file to go away, I had to just go to the command line and do sudo rm, which finally removed everything off the card, but when I put the P2 card back into the HVX200, it said that the card was not formatted properly and I had to format it in the camcorder.
I am a bit wary of using P2 Genie given the glitches that Mac users have mentioned.
Any help would be much appreciated.
Thank you.
Thank you.
