[FS: General] For sale: Mint, fully loaded axis dolly
Tesslacoil
Hi All!
We are selling our fully loaded Axis Dolly in mint condition. We are very sorry to see it go but we are saving up for new equipment! :Drogar-Happy(DBG): This unit is super heavy-duty, and will roll cameras of any weight. It works superbly, and can be set to circles of ANY size from a couple of feet in diameter and up. It can be used as a straight track dolly, a tabletop dolly or a trackless dolly.
The Axis Dolly is the most modular dolly we've ever had the pleasure of working with...
We have used it on dolly track, in full expanded tripod mode, with heavy duty sticks and supporting a fully loaded camera. There were no issues whatsoever. The Axis Dolly is made of 1/2 thick plate aluminum so it will last forever. It's extremely sturdy and it glides and circles super smoothly.
Read the review in DV Magazine: http://www.dv.com/article/15536
Here is the website for the original Axis Dolly: http://www.axisdolly.com/
Here's what we're selling:
Axis dolly with standard casters ($2499 new) (works on hard flat surfaces) - $1600.00
Axis dolly pneumatic casters ($799 new) (perfect for uneven surfaces) - $350.00
Axis dolly track casters ($299 new) (for use on PVC or metal pipe track) - $150.00
Axis dolly T-bar set ($299 new) - $150.00
Cost: $2250.00 OBO
Buyer to pay shipping at cost. (It is heavy.) Email or call with any questions. If you are wanting an inexpensive solution to put top dollar production values into your shots, this is the way.
See pictures of the dolly here: http://photobucket.com/axisdollyforsale
**Other manufacturers have copied the design but this is the original. The Axis Dolly is made with a much sturdier construction and weighs in at 30 lbs fully constructed .. while that may seem negligible, when weighted with a full set of gear, the Axis Dolly is a much better performer on every level.
Thank you very much!
Tess Spaulding
Sunlight Digital Productions, LLC.
info@sunlightdigital.com
310-245-6565
Technical Info:
The Axis Dolly (with the standard casters) weighs about 30 pounds in its full configuration (for use with a tripod), and about 14 pounds in it's mini configuration (for use with a fluid head or tilt plate).
The Axis Dolly in full mode:
1. When folded for travel is 18x27-3/4 inches.
2. When open in standard mode, from the Axis Dolly's center point it is 19-5/8 inches to the center point of the casters, 21-5/8 inches to the outer most point of the legs, and 17 inches to the outermost point of the inside of the spreader cups.
3. When open in wide mode, dimensions increase 2 inches. From the Axis Dolly's center point it is 21-5/8 inches to the center point of the casters, 23-5/8 inches to the outer most point of the legs, and 19 inches to the outermost point of the inside of the spreader cups.
The Axis Dolly in mini mode:
1. Sitting dimensions are 18x16-1/8 inches.
2. From center point to caster center is 8-1/8 inches, and to outer most edge of body is 10-1/8 inches.
3. From center point of any caster to center point of any caster is 14 inches.
