I bought this 15" CRT monitor in 2008 and used it as video tap for shooting two short films. After that, it was garaged.
It works perfectly and comes with a 25 foot component cable, three BNC-component adapters, and a female-to-female composite adapter.
When I bought this unit off B&H, I also bought and installed the JVC IF-C01COMG Component Card, which is pictured below.
I took the photos below today:
This additional photo was posted to another thread from DVX user and shows the monitor with an image on it. Unfortunately, I don't have anything on hand with component out so I'm stealing this one! It's the identical monitor:
I'd like to get $250 + $35 shipping to send it anywhere in the continental U.S. When they sold new on B&H, these two items cost over $800.
I can take PayPal and I've bought and sold a lot of gear on DVX user in the past.
THANKS!
The TMH150CGU 15" Color Production Monitor is a very high performance broadcast monitor with 750 lines of horizontal resolution. The monitor has an all-metal case, is widescreen and 4:3 switchable and auto detects both PAL and NTSC systems. It even has a built-in speaker. Standard from the factory the monitor will accept composite and S-Video inputs. The unit also has an expansion slot for cards that add analog component ins and outs and digital SDI ins and outs.
Superior Resolution
The TM-H150CGU is a very high resolution monitor that is more than capable of displaying its standard composite and S-video inputs. When the expansion slot is used for analog component or uncompressed SDI, the unit shows all that can be shown, adequate for almost any edit suite or production location.
Switchable Aspect Ratio
The monitor will display naturally widescreen 16:9 elements as well as conventional 4:3 video. The TM-H150CGU is ready for widescreen production.
Front Panel Operations
Changing color or other standard picture-look parameters can be accessed right from the monitor's front panel. Phase, Chroma, Brightness and Contrast control are all just a push-button away.
Remote
A D-sub 15-pin connector is built-in to provide the user with the ability to select and change aspect ratio, input source and toggle between overscan and underscan with RS-232C.
THANKS!
