usefulmisfit
Comes with card, cable, software on disc, & Multibridge Pro 2 unit.
The Multibridge is a NEW replacement received under warranty and is still sealed in box.
Remaining warranty until May 2011.
Only recently removed from a MacPro edit suit due to changing careers.
Will courier overseas from Sydney, Australia.
Cost AU $1680. This includes the cost of postal to Australia, New Zealand, US, Canada. All other countries please check first for price.
Payment via PayPal
Best way to get in touch with me is by email: usefulmisfit@mac.com
Here are some specs on the unit....
Multibridge Pro is an affordable bi-directional converter featuring built-in PCI Express. Connect via PCIe to the latest Mac OS X or Windows computers for an incredible quality analog and digital capture/playback solution for editing, effects and paint. Disconnect, and Multibridge Pro changes to a standalone bi-directional video and audio converter for a complete simultaneous analog to digital and digital to analog conversion solution. Features include:
Multibridge Specifications
Connections Multibridge Pro™ Multibridge Eclipse™ SDI Video Input 1 x 10 bit SD/HD switchable. 2 x 10 bit SD, HD, 3Gb/s HD and 2K switchable. Usable as Dual Link HD-SDI for 4:2:2 or 4:4:4 connection or 3 Gb/s for HD-SDI 4:4:4 or 2K. SDI Video Output 2 x 10 bit SD/HD switchable. Can also be used as fill and key outputs. 2 x 10 bit SD, HD, 3Gb/s HD and 2K switchable. Usable as Dual Link HD-SDI for 4:2:2 or 4:4:4 connection or 3 Gb/s for HD-SDI 4:4:4 or 2K. Supported SDI Formats 525 NTSC, 625 PAL, 720HD and 1080HD switchable. 525 NTSC, 625 PAL, 720HD, 1080HD and 2K 2048 x 1556 switchable. Analog Video Input Component YUV/NTSC/PAL/S-Video switchable between SD and HD in Component. Analog Video Output Component YUV/NTSC/PAL/S-Video switchable between SD and HD in Component. Supported Analog Formats 525 NTSC, 625 PAL, 720HD and 1080HD switchable. SDI Audio Input 16 Channels in HD and 2K capture and playback mode. 8 Channels supported in SD.
16 Channels de-embedding supported from SDI input in converter mode. SDI Audio Output 16 Channels in HD and 2K capture and playback mode. 8 Channels supported in SD.
16 Channels embedding supported to SDI output in converter mode. Analog Audio Input 2 Channels of professional balanced XLR analog audio. 4 Channels of professional balanced XLR analog audio. Analog Audio Output 2 Channels of professional balanced XLR analog audio.
2 Channels of unbalanced RCA analog audio for monitoring. 4 Channels of professional balanced XLR analog audio.
2 Channels of unbalanced RCA analog audio for monitoring. AES/EBU Audio Input 2 x inputs on DB-25 for 4 audio channels. Sample rate converted. 6 x inputs on XLR connectors for 12 audio channels. Sample rate converted. AES/EBU Audio Output 2 x outputs on DB-25 for 4 audio channels. 6 x outputs on XLR connectors for 12 audio channels. Audio Capture Support 16 Channels in HD and 2K, 8 channels in standard definition. Audio Playback Support 16 Channels in HD and 2K, 8 channels in standard definition. DVI-D Video Output None None DVI-D Configuration None None DVI-D Resolution None None DVI-D Connection None None HDMI Video Input None Direct HDMI connection supports HDMI capture from HDMI compatible cameras, set top boxes, decks and video games. HDMI Video Output Direct HDMI connection supports HDMI digital compatible displays, such as a TV or video projector. Includes both audio and video. Direct HDMI connection supports HDMI digital compatible displays, such as a TV or video projector. Includes both audio and video. HDMI Configuration HDMI automatically configures to connected display. HDMI Resolution Pixel for pixel HD resolution input to connected device. HDMI Color Precision 4:2:2 10 bit Y,B-Y,R-Y and 8 bit RGB. Multi Rate Support SDI switches between 270 Mb/s standard definition SDI and 1.5 Gb/s HD-SDI. SDI and component analog video connections are switchable between standard definition and high definition. SDI switches between 270 Mb/s standard definition SDI, 1.5 Gb/s HD-SDI and 3 Gb/s HD and 2K SDI. 2K Film Support None 2048 x 1556 at 24fps and 23.98fps capture and playback via SDI. Sync Input Blackburst in SD or TriSync HD. Device Control Sony™ compatible RS422 deck control port.
Serial ports TxRx direction-reversible under software control.
Video Standards SD Format Support 625/25 PAL, 525/29.97/23.98 NTSC. HD Format Support 720p50, 720p59.94, 1080PsF23.98/24, 1080i48, 1080i50 and 1080i59.94. 2K Format Support None 2048 x 1556/23.98 and 24. SDI Compliance SMPTE 292M, SMPTE 259M, SMPTE 259M, SMPTE 296M, ITU-R BT.656 and ITU-R BT.601. SMPTE 292M, SMPTE 259M, SMPTE 259M, SMPTE 296M, ITU-R BT.656, ITU-R BT.601 and SMPTE 372M. Video Sampling 4:2:2 and 4:4:4 SDI & analog switchable. Color Precision 4:2:2 10 bit and 4:4:4 10 bit. Color Space 4:2:2 YUV, 4:4:4 YUV and 4:4:4 RGB. Analog Composite NTSC/PAL 14 bit and 5x Over-sampled Output. SDI Metadata Support VITC read for 3:2 pulldown removal with DeckLink driver. VANC capture and playback using up to 3 lines of video in file when used with DeckLink driver. HD RP188. SDI Audio Sampling Television standard sample rate of 48 kHz and 24 bit.
Processing Colorspace Conversion Hardware based real time. HD Down Conversion Supports playback from HD to SD. Supports down conversion on capture from HD video input to SD files. Anamorphic, letter box and center cut formats selectable. HD Up Conversion Supports capture from SD and 720HD video input to 1080HD files. Real Time Effects Apple Final Cut Pro internal effects on Mac OS X™.
Adobe® Premiere Pro® internal effects in DV, MJPEG and uncompressed edit formats.
DeckLink Driver Extras Configuration Software Blackmagic Design System Preference and Control Panel. Software Included Deck Control, Disk Speed Test and Blackmagic QuickTime™ driver. Installation Connected via PCI Express cable and plug in adapter card on compatible PCIe Windows systems. Connected via PCI Express cable and plug in adapter card on PCIe Apple Mac OS X systems.
Please see the full system requirements for Mac OS X and Windows.
Extras Software Control Multibridge Utility included free for Windows XP™, Windows Vista™ and Mac OS X™. Firmware Upgrade Automatically upgrades when new software is installed. Installation Reversible Rack Mount. Adhesive rubber feet included. Product Warranty 3 Year Limited Manufacturer's Warranty.
Payment via PayPal
- Dual Link SDI 4:4:4 capture and playback, HDMI capture and playback, and analog component, NTSC, PAL and S-Video capture and playback. Multibridge Pro will convert from SDI to Analog/HDMI and Analog/HDMI to SDI simultaneously.
- All SDI connections are the new 3 Gb/s SDI, so the new Multibridge Pro can capture and play back 2K feature film resolution at 24 fps and 23.98 fps, 2048 x 1556 resolution when used with HDLink Pro.
- For audio, Multibridge Pro includes 8 channels of AES/EBU digital audio in and out, as well as 2 channels of XLR balanced analog audio in and out.
