Food shots with the DVX100A
Segarza
Hi!
Here's 20" of fruits and veggies. Shot at 24P, will post the scene scettings shortly. This is intended to air on NTSC TV so I just deinterlaced when enconding to MP4, you may noticed the stutter of the 2:3 "deinterlaced" pull down.
Regards,
Salvador
http://www.comdig.net/segarza/food.mp4
(20MB)
Re: Food shots with the DVX100A
VERY nice. Well lit, and the pans were smooth as butter (may I ask what tripod). Even the telephoto shot was smooth.
Deinterlacing turns 2:3 pulldown into 2:2:4, but even so it was pretty smooth. I loved the lighting, and the lack of noise is surprising in a dvx but very nice.
Thanks! We actually used an EZFX Jib mounted on a Bogen 3191 tripod. Our lighting kits we being used in another shoot, so I ended up using the modeling lights for a couple of monolights. Bounced one on the white ceiling and shined one through a translucent umbrella (positioned a bit to the side/back, from above). Also used a Silver LiteDisc on a couple of shots.
Did some scene setting tweaking to get the look I was after, and crushed the blacks a bit to reduce noise problem.
Settings:
Detail Coring: +3
Chroma Level: +1
Color Temp: -1
Master Ped: -5
Gamma: Cine-Like_V
Martix: Enriched
V Detail Freq: Mid
Progressive: 24P
Shutter: 1/48
Aperture: Around f2
Zebra at 90IRE, specular highlights were either at or below 90IRE.
I figure I underexposed about 1/3 to 1/2 stop.
Everything else was either 0 or default.
This is actually the first time in a year or so, of getting away with little or no noise in the images.
Here are a couple of stills:
seemed very jerky to me, probably because of the +3 detailsetting. how does it look on TV?
Looks good on TV. Client loved it. Jerkiness is probably due to the speed of the camera moves and also because I didn't remove pulldown before compressing it for the web, simply deinterlaced.
