Christopher Barry
1. I understand that RedRock improved their Follow Focus with Rev 3, as per this FreshDV review. The gear lash is said to have gone down from 4mm to 5mm (Rev 2), to about 1.5mm to 2.0mm of gear lash with Rev 3.
2. The next FF I am considering is a Cavision. Can anyone advise what, if any, gear lash exists, or perhaps someone who has used both can provide a comparative comment/opinion?
3. Cavision, what whips (connection) does it take? Can you use the RedRock whips?
4. Cavision, how do you adjust the arm tilt? Is it spring loaded or screw adjustment or does that lever on the barrel release the arm, you adjust and then position the lever back to lock down the arm position?
Thanks.
Thanks.
