Selling FOCUS ENHANCEMENTS FS-H200 Portable Compact Flash DTE wtih almost ONE YEAR WARRANTY LEFT
For $750, includes Shipping anywhere in the U.S.
Bought it brand new about 3 weeks ago. Used it Only to test with my Canon XHA1 and then decided to buy a used Tapeless camcorder.
This comes in Original Box with all original accessories and still has almost one year warranty that it came with.
Item Includes in Original Box:
-Focus Enhancements FS-H200 Portable Compact Flash DTE Recorder
-Lithium Ion Rechargeable Battery
-4-Pin to 6-Pin FireWire Cable
-USB Type-A to Type-A Cable
Features
-The Direct To Edit Advantage: With the FS-H200 Portable Compact Flash DTE Recorder, you will go from acquisition to editing with unparalleled speed, efficiency and reliability
-Industry Standard File Format Support: The Focus FS-H200 brings the most popular DTE file formats to solid state recording. When used with 25Mb/s HDV cameras.
-Removable Compact Flash Slot: The FS-H200 features a CF card slot on its side for insertion of standard Type 1, UDMA, 266x minimum Compact Flash Cards ( 16GB min.).
-Native QuickTime HDV Support: With the FS-H200, you can record 1080i 50/60 or 720p 30 clips as native QuickTime HDV. The FS-H200 extracts and decodes the audio from the incoming HDV stream, combines it with video stream and wraps is as a QuickTime HDV file.
-Designed to Transform Workflow with Industry Standard Removable Media: FS-H200 allows you to go straight from shooting to editing by recording video in the NLE-compatible file format of your choice.
-Powerful, Flexible and Easy to Use: The FS-H200 ultra-reliable solid state DTE recorder to record a wide range of HDV and DV formats and navigate quickly and easily using the intuitive menu structure.
-Perfect for Extreme Conditions: Trouble-free recordings in extreme shock and high altitudes. Record in temperatures up to 120 degrees F (50 degrees C)
-Silent Operation: Enjoy quiet operation made possible by a true solid state media recorder with no moving parts.
-Weighs 12 oz.
Features
-Weighs 12 oz.
