SOLD Flycam Nano Stabilizer W/ Arm Brace For DSLR/HDV Cameras
Status
Not open for further replies.
HD-tography
“Very Lightly Used” Condition
Modified Handle Includes Pro Rubber Grip With Flange That Prevents Hand From Slipping Upwards Into The Gimbal (Original Foam Grip Also Included)
Includes Foam Padded Arm Brace that mounts securely around your forearm
Top Plate Covered Neatly With Gaffer Tape To Prevent QR Adapter Slippage (This May Be Removed If Desired)
Price: $160.00 + 3% PayPal Fee (Or Send Money As Gift) + Actual Shipping to ConUS, Canada, and some places in Europe (PM me for shipping quote)
Shipped From North American Location (Canada) The Day Following Cleared Payment
I only accept PayPal
Also Check My Other Items For Sale, Massive Liquidation Of New & Like New Professional Camera & Cinema Gear! Everything Must Go!
To See Even More Photos Of This Massive Sale Visit:
http://photobucket.com/TheGreatLiquidation
Specifications :
This Stabilizer is made of aluminum and has a black powder coating
Camera Platform knobs made of strong and durable plastic
Modified hand-grip includes rubber grip and rubber collar to prevent hand sliding upwards towards gimbal
Weights made of MS nickel
Each weight disc dia: 48mm
Each weight thickness: 4mm
The weight fastening screw: 1/4"
Stabilizer weight: 2.2lbs
Weight of one weight disc: 54grm
Length of Stabilizer: 10"
Complete Length with telescopic: 14"
Top plate dimensions: 5.25" (L) x 3"(L)
Dia of sled: 16.25mm
Colour of stabilizer: Black
Gimbal bearings made of SS
Platform covered neatly with gaffer tape to prevent slippage of QR adapter (can be removed if desired)
Gimbal Specification:
Wheelbarrow bearing provides Rotational control over camera so the camera can be easily rotated on its axis.
Grip swivels left and right from the bolt. You can easily move whole steadycam up and down.
Angle bracket enables grip to move up and down.
Balancing the camera:
This stabilizing system contains weights. Main function of these weights is to balance your camera on this stabilizer.
You can add or remove weights as per your requirement.
The weights are fastened on the weight plate with 1/4" screw
Features:
The FLYCAM nano has a camera platform with both x and y adjustments. It has many holes on the top plate so as to mount the camera at any position.
The handle is very smooth and stabilizes your camcorder on FLYCAM nano without any jerk.
The weight plate contains sixteen weight discs to balance your camera on the stabilizer
The FLYCAM nano has telescopic feature and hence its length can be extended
Designed for DSLR Cameras & Mini DV/HDV camcorders weighing up to 900 grams. The FLYCAM nano stabilizes the smaller cameras perfectly to be used for handheld shootings in weddings, parties, and independent filmmaking.
The FLYCAM nano is a very light in weight and fully equipped with its special qualities of balancing the smaller camcorders and hence giving a feel of professional video-makers to the independent video-makers.
Imagine a world in balance. Imagine smoothness, freedom and grace. With FLYCAM nano, Camcorder seems to float, always balanced, isolated from any undesirable movements of your hand.
Working with FLYCAM nano you would no longer need a tripod or a dolly. All you need is your Imagination! Now you can attach ARM BRACE with FLYCAM nano for more stable and steady shots.
The Arm Brace is very useful for all cameras. Not only does it give you the ability to use the Flycam for longer periods of time, it also removes a lot of the strain from your wrist.
The Arm Brace is foam padded and mounts securely around your forearm, using elastic Velcro straps for quick access and individual fit. It has an aluminum bar that runs the full length of the brace. Attached to the end of the bar is an aluminum post that inserts into the handle of the Flycam, allowing your arm to support the weight. Your palm and fingers wrap around the handle to provide additional support and control.
The angle of the handle can also be adjusted by choosing one of the additional mounting holes for individual comfort and a variety of shooting positions. Examples are straight up for low shots and straight out for higher shots.
Status
