Fluorescent Lights
ItsJanosz
Hey All,
Have a question about working with the DVX under fluorescent light. Shooting in 24P, and there are a couple of setups where we are shooting under fluorescent light. We won't be able to swap them out for kinos, and I have done some tests and gotten some strobing and flickering in a few cases. Any advide on settings/ways to avoid/minimalize this? I like the look of the lights as long as I can avoid the flicker. Thanks!
Re: Fluorescent Lights
The flickering occurs due to shutter speed being shorter than the electrical frequency (USA 60Hz and EUROPE 50Hz).
This means that you need to have a minimum shutter speed of 1/60 or turn it off if you want a flicker free footage.
Modern video/photo lights are solving this problem with "ballasts", which give a very high frequencies of light.
Hope this helps.
Cheers.
Also, switching the Cinne Matrix to FLUO will boost your warm colors so people don't look pale and green.
If you're getting flicker, try a longer shutter speed (in 24p, try 1/36 or so) and see if that helps.
