Denniscasey
I am doing step by step upgrade (budget limitations) to video starting with purchase of HMC40. Next on list is upgrade to my old Vivatar sturdy tripod with friction head. Tripod itself is quite good although heavier /longer than I want for travel. So plan is to first get decent fluid head then later get lighter weight/smaller tripod for head. Two main uses are race cars (fast smooth pans desired) and scenery (slow stable pans).
Main feature I think I need is adjustable drag to allow for fast race car pans as well as slow scenery pans. Don't want to spend a lot but looks like $400 or so is entry point.
1. What recommendations do you have at this price point (Greg, Sachtler you mentioned earlier looks beyond my price point).
2. What other features do I really need (mostly I do handheld, but now see need for tripod so lacking experience in using tripods).
The one option I have come up with so far is described below (from B&H)
Being very much aware of changing trends in the video world, Manfrotto revised their proven 503 fluid head taking into account the increasing performance demands of High Definition Mini-DV camcorders. The result is the 503HDV Pro. $360
With regard to ergonomics, the engineers at Manfrotto designed the 503HDV with entirely left-handed controls to enhance operational efficiency. Since camera controls are generally left-handed, every setting may be inspected and verified at a glance, facilitating rapid setups from shot to shot.
The greater resolution of High Definition video means that details as well as errors in movement are more apparent, and thereby demands a more refined means of support. The continuously-variable fluid drag system of the 503HDV provides just the right amount of dampening for any shot on your list-from whip pans to slow motion, just dial in drag to touch. This capability in conjunction with the 3-step counterbalance delivers the type of fingertip camera control normally reserved for much more costly production fluid heads.
ENG crews and independent filmmakers alike will appreciate the thoughtful, full-featured design of the 503HDV fluid head as it expands their shooting gamut without unnecessarily shrinking their budgets. As with all other Bogen/Manfrotto supports, it includes a two-year warranty and comprehensive online documentation.
Continuously-variable fluid drag
Multi-spring 3 step counterbalance
Sliding balance plate with 58mm of travel
Replaceable dual pan arm rosettes
Illuminated bubble level
Thank you for advice, Dennis
