Flowers
Lez,
I can get your other stuff on Vimeo to play, but I can't get this one to play, and I've tried it three different times.
Two this morning and one this afternoon.
Seamus+
will check what's going on at vimeo.. I'll reload it... seems like things are a bit funny.. I've lost thumbnails etc on the site... cheers
.... I've reloaded the video and seems to play fine...
http://vimeo.com/6605095
Cheers
Looks great, Les! The colors certainly pop. Was that the "spark" scene file on the 300? Any other settings/glass you used that you can share?
Scene Files are set as following..
SCENE NAME :LESSK
00005000: 0 ; VFR : ON
00005001: 50 ; FRAME RATE: 50 FRAME
00005002: 021C0708 ; (SYNCHRO SCAN):
00005003: 11 ; DETAIL LEVEL: 3
00005004: 8 ; V DETAIL LEVEL: 0
00005005: 9 ; DETAIL CORING : 1
00005006: 12 ; CHROMA LEVEL: 4
00005007: 8 ; CHROMA PHASE: 0
00005008: 8 ; COLOR TEMP Ach: 0
00005009: 8 ; COLOR TEMP Bch: 0
0000500A: 127 ; MASTER PED: -1
0000500B: 16 ; A.IRIS LEVEL: 0
0000500C: 0 ; DRS EFFECT: 1 (should be off ..)
0000500D: 4 ; GAMMA : B.PRESS
0000500E: 2 ; KNEE: LOW
0000500F: 0 ; MATRIX: NORM1
00005010: 1 ; SKIN TONE DTL : OFF
00005011: 0 ; V DETAIL FREQ : THIN
Cheers
I wonder what would happen if you saved the DRS effect to 0 in the scene file??
It doesn't matter what you set DRS EFFECT to, it has to be turned on to do anything. So unless you've assigned it to a User button and turned it on, don't worry about it.
