Dennis Wood
DVXuser Sponsor
Just curious if anyone has a nice technical reference to proper back focus adjustment on B4 lenses? The Fujinon 17x manual procedure leaves a few important points out (at least in my mind).
1. They indicate to place a focus chart "approximately" 9 feet away from the lens. Measuring from what? I'd assume the lens surface based on their description, but normally I'd be looking for the equivalent film plane point on the HPX500.
2. I'm assuming that the focus mark on the lens should also approximate 9 feet, and that if back focus is correct, zooing in and out should retain sharp focus. This is what I used as the final determination as it's the only reliable way of setting focus, quick zoom or otherwise.
3. But....I cannot get infinity focus sharp at the physical end of the focus ring pull (regardless of back focus setting). I've got sharp infinity focus just before the focus ring physical stop. It seems I need a touch more adjustment than provided.
Any insights?
Any insights?
