SOLD Flanders Scientific FSI LM-1760W HD Monitor
Status
Not open for further replies.
truelife
Excellent condition 17" FSI Monitor. Only blemish is a few scratches on backside. Screen is immaculate and has been protected since Day 1. $1350 shipped. I've sold many items on here before and been a member for over 8 years. Feel free to ask questions.
Includes:
Petrol case
VESA Mount
power cable
user CD
extra Velcro strips
screen protector
firmware cable
Description from manufacturer:
The FSI LM-1760W is a 17" Multi-Format LCD monitor with HD/SD-SDI, Component (YPbPr/RGB), Composite, DVI-I, and Optional 3Gbps SDI Inputs. This unit is packed with many common broadcast monitor features like Blue Only, MonoChrome, Markers, Safety Areas, & Tally Lights and like all FSI monitors it also comes standard with advanced features like our 12 Mode Scopes, Focus Assist, Time Code Display, LUM Coloring Exposure Check, Freeze Frame Picture and Picture, Audio Disembedding, and Audio Level Meter features.
The LM-1760W is ready for virtually any application with instantly adjustable Gamma & Color Temperature Presets and true Multi-Format support ranging from NTSC/PAL to HD and 2K. Additionally, the LM-1760W can be ordered with optional 3Gbps SDI Inputs (SMPTE 425M) for support of 1080p50/60 or 1080i 4:4:4 signals over a single Serial Digital Interface. Standard DC (24V) and AC (100~240 VAC) power connectors add to the unit's flexibility and applicability for almost any environment.
Features
Timecode Display (VITC 1, VITC2, LTC)
Automatic Source Resolution & Frame Rate ID: toggle on, off, or temporary 5 second display when format change is detected or input button is pressed
DSLR Zoom feature for full screen scaling of DSLR video source at both 480 and 1080 resolutions
On-Screen Alarms (IRE Threshold, RGB Alarms, Loss of Signal, Audio Mute, and more)
Adjustable Focus Assist (Focus Meter and Focus Highlight in Red)
Wide Variety of Standard Markers & Safety Areas
Pixel Zoom Feature - High Quality Adjustable Zoom on any portion of HD signal
CX Scale (video example): Full Screen and centered scaling of Codex ARRIRAW Recorder output
User Adjustable Custom Marker Feature
Active Video Boundary Marker
H/V Delay
Blue Only
Monochrome
Overscan/1:1 scan
Freeze Frame Picture by Picture
12 Mode Scopes (Luminance Waveform, Vector Scope, RGB Parade, GBR Parade RGB Overlay, YRGB Peak Column, Histogram, Color Histogram, RGB Histogram, YCbCr, YCbCr Overlay, & Audio Phase Meter)
Audio Disembedding
Audio Level Meters
Advanced Measurement Feature
Exposure Level Indication with LUM Coloring feature
Color Temperature Selection
Gamma Selection (1.0~2.8)
SD Aspect Ratio Selection (Anamorphic/4:3)
Remotely Controlled Tally Lights (Red/Green/Amber)
AC or DC operation
Diecast Aluminum Frame
Status
