SOLD Flanders Scientific CM170 17 Inch Monitor
Status
Not open for further replies.
Ryman
For Sale:
Selling my Flanders Scientific CM170 monitor.
Monitor is in MINT condition, not a mark on it, and has had the acrylic screen protector on since purchased new.
Comes with monitor, screen protector (few scratches on screen protector), and AC cable.
Looking for $1750.00usd shipped to USA/Canada.
Please pm or email directly.
thanks.
Specs:
The Flanders Scientific CM-170W is a 17″ Multi-Format reference monitor with 3G/HD/SD-SDI, Component, Composite, & DVI-I Inputs. The unit features a full 12-bit video processing and a 10-bit panel capable of reproducing over 1.073 billion colors on screen. The CM-170W supports virtually any signal format from NTSC/PAL to HD and 2K, including advanced 12-bit, 4:4:4, and XYZ signal formats. With its wide gamut 10-bit panel and advanced Color Fidelity Engine the CM-170W is essentially a more compact version of FSI’s popular 24” reference monitor, the LM-2461W. Thanks to its ultra-wide gamut LCD Panel the CM-170W has the unique ability to work in several different color spaces with an instantly selectable menu option. Choose between REC 709, SMPTE C, EBU, DCI-P3, or native Wide Gamut Mode.
One favorite feature of the Flanders’ monitors are the standard 14 On-Screen Scopes. Up to two types of Scopes can be displayed simultaneously and can be toggled on/off instantly with a single button press. Scope Windows can be displayed in any of 6 onscreen locations and the two scope windows can be stacked on top of each other or sit side by side for maximum flexibility. FSI is also one of the few companies to provide this scope functionality across all inputs, even DVI. This means that full scope functionality is possible while using many of today’s most popular HD-DSLR cameras that only offer HDMI output. Additional instantly selectable gamma, peak luminance, and color temperature presets add to the flexibility of this unit making it suitable for a wide variety of applications and environments.
Technical Specs
Panel Specifications
Screen Size 17.3"
Resolution 1920x1080
Bit Depth (Color) True 10 bit (1.073 Billion Colors)
Contrast Ratio 1000:1
Max Native Color Gamut
Backlight RGB LED
Pixel Efficiency 99.99%
Max Luminance 250nit
Viewing Angle 178°
Inputs
1 x DVI-I DVI-I (Analog/Digital)
2 x BNC 3Gbps/Dual Link/HD/SD-SDI
1 x BNC Composite
3 x BNC Component (YPbPr/RGB)
Outputs
1 x BNC Composite
Supported SDI Formats
ITU-R BT.656 (PAL) 576i (50)
SMPTE-125M 480i (59.94)
SMPTE-274M 1080i (60/59.94/50)
1080p (30/29.97/25/24/24PsF/23.98/23.98PsF)
SMPTE-296M 720p (60/59.94/50/30/29/25/24/23.98)
2K 2048x1080 (30p/30PsF/29.97p/29.97PsF/25p/25PsF/24p/24PsF/23.98p/23.98PsF)
SMPTE-372M 1080p (50/59.94/60) 4:2:2 YCbCr, RGB
1080i (29.97/25/24/23.98) 4:4:4 YCbCr, RGB
1080p (30/29.97/25/24/23.98) 4:4:4 YCbCr, RGB
720p (60/59.94/50) 4:4:4 YCbCr, RGB
SMPTE-425M-AB
- Level A & Level B supported
- Level B supports 2 x SMPTE
292M image format mapping
372M image format mapping
- RGB, YCbCr, & XYZ supported 12 & 10 bit 4:2:2 1920x1080p (60/59.94/50)
4:4:4 1280x720p (60/59.94/50/30/29.97/25/24/23.98)
12 & 10 bit 4:4:4 1920x1080i (60/59.94/50)
12 & 10 bit 4:4:4 1920x1080p (30/29.97/25/24/24PsF/23.98/23.98PsF)
12 & 10 bit 2k (2048x1080)(30p/30PsF/29.97p/29.97PsF/25p/25PsF/24p/24PsF/23.98p/23.98PsF)
Supported DVI-I Formats
DVI-Analog & DVI-Digital VGA (640x480), NTSC (720x480), SVGA (800x600), XGA (1024x768), SXGA (1280x1024)
DVI Digital Only 1280x720, 1440x900, 1920x1080
Audio
Audio Disembedding Yes
Audio Level Meters Yes
Internal Speakers 2
Audio In (Mini-Jack) 1
Audio Out (Mini-Jack) 1
Status
