accentphotography
I purchased a used DVX100b and I did not realize at the time that the manual focus ring was not 100% perfect until I took it home an really learned the camera. What I realized is that the manual focus on the DVX100b is performed by the focusing ring rotating stopless either left or right as the focusing ring has small teeth on the inside that go between optical sensors located on the bottom of the lens assembly to tell the lens to focus in or out. After realizing that the plastic mounting area had the screws stripped or cracked I proceeded to contact Panasonic for a OEM Repair Manual and Parts Catalog. Guess what ... the lens is considered an assembly and there is no break down for what seems to be a cheap plastic ring. If I had known this I would have never spent the $58.00 ordering the repair manual.
Any suggestions or idea of where I can go to get a better individual part number instead of the whole assembly? I had heard that Panasonic requires you to buy the Repair/Parts manual first and that they could possibly guess which part was needed after you bought the book but I was not sure if that was true or a urban legend.
Help:violin:
Help:violin:
