plasticam
DVXuser Sponsor
Ok here is a a mocked up prototype of the new Shooting Machine walnut side grip. Code named Pistolbunny (it looks like a bunny!) it will trigger the FS100 and FS700. Made of black walnut, hand carved and finished (no CNC). Made right here in USA. IT HAS SONY MENU ACTIVATION. I'll report back tomorrow on what- I'm planning on EXPANDED FOCUS and DISPLAY and the 6 user PRESETS - all on a thumb joystick with "center enter". It fits to rosettes or rods with dual axis control - and from the new FS700 rosette - height control. It's pretty adjustable. it's darn smart too - with a Diplomatic brain that speaks Sony fluently. The trigger has a hinged security guard to prevent misfires- heck why not! More info coming soon. We're still carving and coding- I just wanted to let you know what we had cooking here.
Also a new Full size Cheeseplate and matching Over the Lens rod clamp.
These fit the FS100 now and will fit the FS700 and several other cameras in the coming weeks. It attaches to the FS100 and 700 the same way our ShotGrip handle does- the strongest 4 point connect out there. Custom designed for the Sony FS series camera's not just a flange with two screws. This works with our top handle or as a stand alone with anything you like using. Sold separately. Pricing is on the way soon. Will also bundle with Shotgrip handle soon.
Our Low Profile "stub clamps" were so handy I started attaching all kinds of things they were never designed for. Well now they ARE. These products will put gizmos about anywhere- and save you money doing it. Introducing:
Gender benders. 1/4 20 "gender benders" turn any 1/4 socket from male to female or vice versa- with a locking finger nut.
Turret Mounts. Turrets are like a mini "tank gun turret". The rounded turret threads into any female stub clamp and then rotates 360 degrees with a slot head lock down screw that you can "coin op". The screw is easy to access- right where the circular "hatch" is on a tank (where you toss the grenade down.) Turrets change the direction of the male 1/4 stud 90 degrees- and rotate 360. yeah?
Stud plugs. We sell threaded rod now and new threaded "Stud Plugs" (these fit zacuto threaded rod too) the plugs screw right in the end and gives you a 1/4 male stud at the end of the barrel.
C-48's. Plain old 1/4 20 studs with lock nuts. Have a cheeseplate? you'll want a handful of these.
All these little connectors make sense immediately when you see them. Hard to describe in writing!
I hope they'll make a lot of things that are gommy and expensive - simple and affordable. And my personal favorite - adjustable!!
Thanks all
