Received the HPX500 yesterday. I called B&H last week to check on the status of the order and was told it was being held because they were waiting for the tripod plate. I asked that it be shipped anyway, got it yesterday and clicked it in to our old tripod plate.
The camera body is very light, but when you attach the lens and battery it weighs about 16 lbs. If you're transitioning to this camera from the HVX the added weight and size of the camera can be overwhelming.
The camera's menu system is the same as the HVX. The only difference is there are a lot more settings, features and menus to choose from. If you are an HVX owner you will be able to use the camera right away without looking at the manual.
The LCD screen seems to be of very little use. The color seems to be off on it and it is very hard to focus with - for obvious reasons.
I used the Viewfinder a lot more than the LCD. It is very easy to focus with the b&w viewfinder. The LCD is only good whenyou are looking at clip thumbnails in MCR mode or going through the menu, otherwise it got in the way of normal shooting.
The focus assist feature is not the same focus assist feature on the HVX with the magnified portion of the screen. it is a focus graph in the upper right corner of the screen.
The lens that I ordered is the XA17x7.6BRM-M58B. It is hard to access the quality of the lens because I can't compare it with others.
The image quality on the camera is much more cleaner than the HVX. That was noticeable right away. It is a very professional camera that will produce really nice images. However, with the exception of the noise in the signal, the HVX200 isn't that far behind in quality.
Hopefully I will get some images to post for everyone.
