digitalgecko
Well I guess it had to happen, and if you were to ask I would have said it would be the first to break. Yes, the little RCA video out jack on the side of the camera. I know most don't use them and there is SDI out, but when you have to shoot an event and they want to put a camera on the big screen, they are not usually using really expensive or professional equipment and they always ask for composite video. I've only used it once before at the same venue and it worked well. I used a very light RCA cable, and I thought all was well. They called today and I went out there to check out there setup and I connected the camera and no video out. I checked the menus to see if it is possible to turn off the composite video output and no, it's on all the time. So I'm brushing off my old Sony Z7 to shoot this one. It has a priority cable connection that breaks out into composte video and audio. A more solid design than flimsy RCA connections. It's sad because I do love everything else about this camera.
My question is has anyone come across a reasonably priced SDI- to composite coverter. That may be a better way to attack this issue?
