Mat Cain Member May 3, 2010 #1 How do I know what firmware is currently on the camera and what is the latest?
davideo.net Well-known member May 3, 2010 #2 It's at the last page of the menu. I believe (correct me someone if I'm wrong) that it's 9.34
J jmarkham Well-known member May 7, 2010 #3 Yea . go to the menu and jog-wheel until you get to the last item which is called "Diagnostic" In the upper-left part of the screen, you'll see "VERSION" and directly under that you'll see the version number of the firmware. jeff
davideo.net Well-known member May 11, 2010 #5 go here: https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft/upghpx300_e.htm and be sure to print out the installation procedure PDF, since the instructions are complicated. You need an SD card (formatted in the 300.) 9.34-00-0.00 is in fact the latest firmware.
