Firmware Update on AF100, and the Mac
Barry_Green
Moderator
*** EDIT ***
Panasonic has introduced a new firmware update to fix this issue.
http://www.dvxuser.com/V6/showthread.php?239320-New-Firmware!&p=2254487#post2254487
Of course, in order to install this new firmware, you will have to have a clean SD card with no AppleDouble file, for this one last time. So the workarounds in this thread here would still be needed to be employed one last time.
Or, you can use this:
https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft/mac_update.htm
They've created a small utility specifically to address this issue, so any Mac user should now be able to update the firmware easily without resorting to third-party utilities or whatever.
*** END EDIT ***
There's a new firmware update out for the AF100, version 1.14-00-0.00, available at this link:
https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft/upgaf100_e.htm
According to the release notes, it fixes a bug when using SDXC cards and the SD Card File Recovery Software program.
Some people are downloading and installing the firmware update effortlessly. And others are unable to get it to work. I've been digging and found out what the problem is...
First, those who can't update the firmware are on the Mac platform. And the problem appears to stem from the Mac OS's insistence on writing invisible files to the card. Stick a card in Windows, and pull the card out, and it will be as it was. Stick it in a Mac, and immediately the Mac will write invisible files on the card, like a "trashes" directory, and sometimes duplicates of other files. Those files are confusing the AF100. I don't know why the Mac feels it needs to do this, but it does it, and that causes the problems.
I formatted an SD card in the camera, stuck it in Windows, and looked at the files and folders -- there were the usual, "DCIM", "MISC", and "PRIVATE". I then ejected the card, stuck it in a Mac, then ejected the card from the Mac and put it back in a Windows system, and now there are new files there: there are three invisible files, ".fseventsd", ".Trashes", and "._.Trashes". Some of these files are apparently called "AppleDouble" files, and are part and parcel of how OSX operates.
So now here's where the problem comes in -- if you download the firmware update, it will download one file: "vsi5257h.zip". If you extract that file, you should get exactly one file on your card: "VSI5257h.img". And on Windows, that's what you get -- and if you put that card in the AF100, it will recognize the presence of a firmware update file, and it will start the update process, exactly as it should.
But on the Mac, that's not what happens! On the Mac, if you download the firmware update, you'll get the .zip file. If you then extract the .zip file, it will make TWO .bin files! It creates the proper "VSI5257h.img", but it also makes a spurious/bogus "._VSI5257h.img" file, which is (I believe) an AppleDouble file. And that's the problem. That's what's stopping the AF100 from being able to update its firmware.
So what can you do about it? Well, really, all you need to do is delete that bogus file. If there's some way on the Mac to delete a hidden file, delete it, and everything should work just fine.
If you can't find a way to delete a hidden/AppleDouble file on the Mac, you can take the card over to a Windows system and use that to delete the hidden file.
Or, you can use software that doesn't create the bogus/duplicate file in the first place. The problem apparently comes from the Apple OSX unzipper software. If you use alternate unzipper software, you can avoid that duplicate invisible file. One such example is Keka software, which you can get free at www.kekaosx.com/en. Keka 0.1.4.2 will unzip the .zip file and make only one .IMG file, without creating a duplicate. And that extracted file will work in the AF100 directly.
Obviously I've recommended to Panasonic that they figure out a way of sensing a real .IMG file vs. an AppleDouble file. And if they do, that'll be in some future firmware update. And in order to install that, you'll still have to go through the process of getting only the one, valid .IMG file on your card. So you're gonna have to go through this process anyway.
I haven't used the Keka software; I don't know anything about it and therefore I can't endorse it, I leave that up to you Mac users to try and verify. There might be other free/downloadable unzippers that avoid the AppleDouble issue. Or, there might be a way to delete AppleDouble files. I hope some Mac users will weigh in with what they've done that's worked, and explain the process.
But if Keka works, it seems like a relatively simple way to solve the can't-update-firmware-on-a-mac issue.
Without Barry Green we would be children lost in the forest. In this case a forest of obfuscation via "instructions."
Thank you, Barry! I used Keka and am now upgraded.
Should be a sticky. And, more importantly, should be on the Panasonic upgrade page instructions!!!
Good shooting and best regards,
Leo
Hey Barry, Leo's idea to make this a sticky is a good one.
This hidden file thing is something that has been ongoing for years, and not just on an SDHC card. Plenty of quirks on the P2 side as well.
Best,
Jan
I just used Stuffit Extractor on my mac to unzip the file, copied to my sdhc card, connected the a/c adapter to the camera and its updating without a hiccup!
I've been trying to update firmware from a Mac for 2 days now.... with no luck. I'm now trying a Mac with Leopard. I only see the .img file through many folders. If I read correctly, I should keep this in the "Private" folder and overwrite that folder onto my card. It still isn't working. Does it need to be a SDXC card? I'm using a Lexar SDHC 16 gig card.
thanks - dlpark
I added a link to this thread in the "Tips & Tricks" sticky. We're starting to get a bit sticky-heavy in the AF100 section already, so I don't want to do too many more; hopefully everyone can find what they need in the Tips & Tricks thread.
Glad it's working out for folks.
THANKS wbrock001.....after MANY trials and experiments, your Stuffit trick worked!! Had to fiddle with the Mac so it won't try to unzip as I downloaded. Thanks again.
dlpark65
Brian said "How come it worked with my HVX200 and not my HPX170 and AF100?"
I don't believe it worked on the HVX200 for everyone. I have been answering this question for years.
Best,
Jan
Is there anything else in this firmware update? I don't use sdxc cards. Any need to do the update if that's the case?
I don't think so, but it wouldn't be a bad idea to do it anyway just in case you rent your camera out to someone that is using SDXC cards.
Also I can verify that Barry's suggestion works. I just updated via Keka, and it worked perfectly. Thanks Barry.
Have to admit this whole thing is making me do a slow burn. I mean it's not like I'm on some obscure platform with an OS I've written myself. For Christ sake the Mac is used by countless video professionals. I really don't expect to have to find workarounds just to install a firmware upgrade. This is not a Mac thing. It's a Panasonic pro division thing. How hard can it be to get this right? And what kind of a company puts out a firmware upgrade with instructions on how to install it on the Mac platform when they obviously never even bothered to test it themselves?!
+1
There has been some neglect of Mac users from Panasonic for as long as i've owned Panasonic Gear, five, six years now. I'm wiling to test beta stuff, I own many Macs.
I used Firefox to download the Oly file, zipeg to open and Voila.
Guess the problem is that Safari opens the download file by default.
It's unix under the covers so why can't you open a terminal window, cd to the mount point, ls -la to see the hidden files, rm -f to remove the unwanted files?
