I have two Laird FW cables for use with DV Rack (On Location). One is 30 ft. and the other is 70 ft. I got them as 6 to 4 and use a 6 to 4 adpator so I can use them with any end configuration, although its always just data moving through them and no power, thus the max is 75 ft. before a repeater is needed.
Firewire [IEEE-1394] defines a media, topology and protocol for both a backplane physical layer or point-to-point serial cable interface. The interface is also called the High Performance Serial Bus (HPSB). On the Apple computer it became the high-performance replacement for the Apple Desktop Bus (ADB).
The backplane version uses two single ended signals and operates at 12.5Mbps [TTL], 25Mbps [TTL], or 50Mbits/sec [BTL or ECL].
The cable (differential) version operates at 100Mbps, 200Mbps, or 400Mbits/sec, [800Mbits/sec for 1394b] using half-duplex [full duplex 8B/10B encoding for 1394b].
Devices on the bus are Hot-Swappable. It supports up to 63 devices at a maximum cable distance between devices of 4.5 meters. The maximum devices on the bus is 16 allowing a total maximum cable distance of 72 meters. Transmitting data over CAT5 cable allows data at 100Mbps to travel 100m [1394b]. Fiber cable will allow 100 meter distances at any speed [depends on the type of fiber cable].
The digital interface supports either asynchronous and isochronous data transfers. Addressing is used to a particular device on the bus. Each device determines its own address.
Most of us who do DV25 transfers on 4pin to 4pin connections have been very successful at thumbing our noses for years at those specs and using long cables.
Do a search and you'll see this subject has already been beaten to death.
